79Civic
<b>is now Color Coated</b>
I agree what you should do first is get the engine and drive train in. Get all of the electrical done and get the car running first. Once that's done you can worry about the looks of the car. The hardest part is going to be getting the car to run and drive, the body work is easy.
i dont see how its that hard to weld in a few plates of metal, drill a hole, and run a couple nuts and bolts and toque em down.... or follow some pictures/written instructions and solder some wire together and add in a few connectors. while i find body work more fun. i find it way harder and requires a lot more skill and an eye for perfections. wiring is just time consuming. not hard.
no i confused 2 forums... he is on a different one. not this one.is he a member here
