99 mirage de coupe, the white virgin.
stock it is a non-blinking marker light solid red when the lights are on. some members wire them up as blinkers.
scrub washed and vacuumed :) 12/24
moving the short shifter over during the weekend. took out the complete center and vaccumed that out too. grosssss
civic front lip for my mirage on the way -
got the e6 tme cluster moved over too.
yup, hybrid cluster.
it was originally like that in the grey car, but then the gauge died so i had to swap in the KPH gauge.
Nah, it's all good. You know I have a soft-spot for KPH gauges.... :D
nice..im pretty sure my friend had that deck in his ef..it worked awesome..
Nice head unit.
Are you going to swap out the speakers soon?
and the civic lip is a close fit or needs modding?
well. yes. EK type R replica lip on. i used 3 rivets in the front, 1/8th in, and 2 rivets on each side, 1/4th in. you need to trim about 1/2 inch off the bottom in the middle to get it to fit, then you can stretch it around the corners of the bumper. i have about 1/2 inch to trim on the edges. going to trim and rivet the pieces to the inner fender, so it matches.
also fixed the window and bent the fuel door to fit. found out today that sedan and coupe fuel doors do not swap :lol: installed the drivers side window visor.
