boostin4fun
Boosted ls/vtec ohh yeah!
I would defintely remove some webbing on the hood vs. trying to compensate by adjusting the mounts. I am going to have the same issue on this crx I just finished up with a ls/vtec. We are going to mark where the valve cover sits on the bottom of the hood and make clearance with a cut off wheel. The bottom of the hood might not be exactly beautiful but at least the outside will! Whenever you replace all your mounts with urethane ones you will have vibration. The main reason cars come with rubber mounts is that they absorb the vibration. The way I see it is, not having any drivetrain movement and getting all of the power to the ground, is worth the vibration.
