how much more boost to run low 11s
Discussion in 'Forced Induction' started by tomtom, Dec 15, 2003.
  1. tomtom
    tomtom Senior Member
    central, cali
    i got a 93 si with ful interior
    motor- ls-vtec (crower rods je piston weld block gaurd) gsr head-ls hydro tranny
    drag turbo kit upgrade to .63 ar and .57 trim
    big greddy intercooler /tail wastegate/blitz bov
    jg intake manifold
    aem fuel rail /440rc hondata s200
    clutch master flywheel/cm stage 3 clutch
    fluidyne rad. fal fan
    walbro 195lph fuel pump
    i will be adding a 50 direct port kit to it soon
    also 720 cc injectors
    with the nitrous how much boost will i need to reach low 11s
    im only running 8psi now
    thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  2. swanny
    swanny Senior Member
    buck teeth and government checks, PA
    it might help if you told us wtf you are running right now.
  3. NotUrAverage_Si
    NotUrAverage_Si Senior Member
  4. pissedoffsol
    and id highly ssuggest upgrading your fuel pump. the 190 is used generally for all-motor cars...
    the 255 for bosoted cars...
    and the 255 hp for serious power cars (400+)
  5. tomtom
    central, cali
    haven t gone to the track yet
    but i can leave a evo 1-2 cars behind
  6. pissedoffsol
    evos run high 13s dude... you have a LONG way to go.
    theres so much more to going fast than power.
    traction, suspension, differentials, weight, gearing, and so much more...
