Negative on the OEM - the alternator I'm running now is aftermarket, but not a 60 amp rated POS from a chain auto parts retailer. It came straight from a shop that rebuilds them. Eagle Auto Electric $153.97 delivered to my front door.Is your 160amp oem?
EAGLE ELECTRIC items - Get great deals on ALTERNATORS, STARTERS items on eBay Stores!
Pictured beside the alternator that came on the JDM DOHC ZC - I assume it to be OEM - but who knows.
So far it's working out real well.
I have the junk aftermarket alternator and the external physical size is very close to what I believe to be the JDM OEM - but, I expect the diodes and regulator circuitry are not as good.
The 160 amp is larger than the chain store aftermarket and the JDM alternators - this one is so big it will probably require the right axel to be pulled for it to drop down when it needs to be removed. Fitment on it is good, bolts right up and wiring harness interfaces correctly.
