But the car's priceless to me....if I get another rex, it just won't be the same.
Right, I know. I don't care what you do with it, I was just attempting to translate, lol...
But what exactly makes it not worth it to some of you? I've done very, very little autobody work and even this looks fixable. Time consuming, but fixable.
It's just their opinion. To truly fix it right you're going to need a new fender, a new mirror, maybe some body work on the door (I don't know if it's damaged or not, but I assume it is), and possibly a new quarter panel or a good deal of work on the existing one, plus paint, and an alignment and possible frame work. To do it up right you could easily spend more then the car's worth.
If the car is that sentimental to you though, then maybe it's worth it. That's up to you to decide...
and where can you get all the tools you need to do this???But what parts of it make it $2000??? Fender: $30-$130. Quater Panel: Not exactly sure the cost, but the steel should only be a few dollars. I know where I can get all the tools I need and garage to work in. So are there hidden problems that nobody's mentioned yet? If there aren't, I don't see the problem.
i can do paint!!!The door's not bad. It might be a little off, but that's fixable. The trim was torn off but I was going to get rid of the trim anyway. It's seriously only got very small scrapes along the side. As for the paint, I'm going to save up for it and do it myself. I also have help with that though, in case I don't do it right. The frame work's the only expensive thing I can see coming into play. How bad is it if you don't check/ fix the frame. I have an idea already...
Step-by-steps on how to do the fender???
