ThatGuy4life
The Riced Sleeper
So after 1 year 1 month, the si is finally out of the shop.
Before:
Built 2000 B18C5-type R motor
2000 Civic Si tranny
Stage 2 port & polish head
Crower rods
JE pistons 12:1 compression
Skunk 2 stage 2 camshafts
Skunk 2 intake manifold
REV Valves Springs & Retainers
Act Flywheel
RPS Six Puck Sprung Hub Clutch
AEM Cam Gears
AEM Fuel Rail
AEM Fuel Pressure Regulator
Vission Fuel Pressure Guage
TrePerformance 255lph fuel pump
440cc fuel injectors
STR Cam Seal
OBX JDM ITR 4-1 headers
OBX High flow cat
AEM V2 cold air intake
Throttle body spacer
APC Cat-Back Exhaust
NGK Blue Performance wires
NGK Iridum plugs
After:
Crower rods
wiseco piston kit 81.5mm-w/ rings 11.5:1 compression
Skunk 2 pro 2 camshafts
Skunk 2 pro series intake manifold
Skunk2 pro series valves and titanium retainers
Act Flywheel
Skunk2 Pro series Cam Gears
AEM Fuel Rail
Skunk2 Cam Seal
Rage Tri Y header
Delete Cat
Skunk2 Mega Power R exhaust
NGK Iridum plugs
PWR half cut radiator w/ fan
Hasport motor mounts
Hondata S300
And some minor other tidbits.
Just breaking her in now will have actual numbers in about 2 weeks once I take it back to throw it on the dyno and tuned
Before:
Crower rods
Act Flywheel
AEM Cam Gears
AEM Fuel Rail
STR Cam Seal
OBX High flow cat
NGK Iridum plugs
After:
Crower rods
Act Flywheel
AEM Fuel Rail
Skunk2 Cam Seal
Rage Tri Y header
Delete Cat
NGK Iridum plugs
Hondata S300
