GlassHeadlights
West West Yall
I'm thinking of turbo'n my Mini-Me to 200, maybe 225 whp. I have 4 grand stashed away but I'd like to spend half that.
So far I have:
-Rebuilt D16A6 block with 35,000 miles on it
-Rebuilt D16Z6 head with 2500 miles on it
-D16Y8 intake manifold
-OBD1 conversion with chipped P28 ECU
This is my list...imput is needed here:
-Walbro 255 fuel pump
-Vitara pistons
-Stronger rods (may do Eagle/Vitara set up)
-Factory bearings
-Turbo
-Manifold
-Injectors
-MAP (needed?)
-Wideband O2 (needed?)
-Spark plugs (needed?)
-B.O.V.
-Clutch (stage 2)
-Stock flywheel
My thoughts are I will yank my motor out, take off the oil pan, leave the crank in and just change out the rods and pistons. When I did my Mini-Me head swap, 2500 miles ago, the block was really clean (35,000 miles old) with a fresh honed surface. Right now its a 10:1 CR, does anyone know what Vitara pistons will do to that?
So far I have:
-Vitara pistons
-Factory bearings
-Turbo
-Manifold
-Injectors
-MAP (needed?)
-B.O.V.
-Clutch (stage 2)
-Stock flywheel
