Korax
It's been a while since I posted anything on my gray hatch. Figured I'd throw a few pics up and where I'm at on this particular car. This car was originally a 91 DX automatic.
Electrical:
Password JDM carbon battery relocate box with Odyssey battery
Full 90/91 DX manual cabin harness swap
Monotech custom Engine Harness
White face gauges with LED backlights (temp before AP1 cluster swap stole from another hatch of mine)
Timex LED tachometer (temp same as above)
OBD0 PW0 ECU (chipped. no idea what. runs rich as hell and can't wait to get this thing tuned right)
Power plant/trans:
OBD0 B16a (stock)
Password JDM carbon EG/EK B series intake
USDM 92-93 GSR cable trans
Exedy 9.5lb flywheel
Hasport mounts
Apexi WS2 catback
Brakes/suspension:
K-sport Rear LCAs (should have went with buddy club or something)
93 EG Si Rear trailing arms/calipers
90-93 DA e-brake cables
Mugen rear trailing arm bushings (can't get new ones from Honda and I wanted a compliant bushing)
Beaks* tie bar
40/40 prop valve
Intergra 1" non ABS master cyl/booster (don't remember from what year)
Goodridge SS brake lines
Rota group N with Kuhmo AST 195/50/15 (not great tires but I got the set for under $200 )
ES poly front LCA and radius rod bushings.
Hardrace front camber kit
Body:
Civic SiR fenders/stanley sidemarkers
Civic SiR stanley clear corners
Honda antenna delete
Other/misc changes:
Non-power steering with power steering rack
89 gas tank (had one laying around and it needed one)
No heating/A/C components (nothing under the dash at all)
Have but not installed yet:
DA front knuckles/calipers
Hawk HPS for DA front calipers/EG rear calipers
DC GSR camshafts
Full set of new style Honda LMAs
Car sound high flow cat
S2K start button and an OEM clip
Looking forward to:
Progress suspension coilovers (getting the cheap ones as this car gets no miles and will go with something better once I know what it is I want)
Progress suspension rear sway bar or OEM ED Si rear sway, haven't decided
Center roll adjusters of some kind
ESP traction bar
Enkie RPF1's with Dunlop star specs
Nascar cage (can't say if it will be in this chasis or not)
AP1 Cluster and needed parts
Cut off switch
Chargespeed rear spoiler
Probably a bunch of stuff I'm forgetting.
Electrical:
Power plant/trans:
OBD0 B16a (stock)
Hasport mounts
Apexi WS2 catback
Brakes/suspension:
Beaks* tie bar
40/40 prop valve
Body:
Other/misc changes:
DC GSR camshafts
Looking forward to:
ESP traction bar
Cut off switch
