Stop with the namecalling and whatnot or the topic will be closed.
As to help you, unless you changed out the ecu, injectors, and distributor, you are still likely running obd1. As for fitting a supercharger kit in a DA, good luck, as there are no kits available, and although a handful of people have gone and put a JRSC or Vortech kit from a DC integra or civic si, it was apparently a royal PITA. Try searching on G2IC.com, there are a few posts with excactly what you are looking for. good luck.
