not all of them are 220,,but anyhow cams,header,exhaust,intake,intake mani,tb,just all the bolt ons will get you there if not more
thanks guys, kinda switching subject, but say i wanted to go turbo, on stock internals, how much hp would the h22a be able to handle safley for daily driving
I'm pretty sure F series sleeves are different/stronger so that doesnt really apply.If AJ's can get 300 hp out of a n/a F22C and the H22 has the same bore/stroke, I can't see a problem getting 220 to the ground, with enough $$ thrown at it.
By-the-way the F22C has 237hp from the factory
I totally agree the h22 motor should be able to push 200-220 horses pretty easily. cai, headers, exhaust, port and pollish, intake manifold, chip ecu and you are probably at 200 if not a little more.
like the responses guys, also any more suggestion welcome, same engine, tranny issue, i have the h22a but it has no gearbox, if drag racing is my main drive, which tranny would you guys use.
iam putting it in a teg, but thanks guys, dont want to go off topic to much cause i know we are in the lude section, but what would you guys pick b16 tranny or the b18c1 gsr tranny with the h2b kit.
