axle replacement
  • Thread starter Thread starter Ky'sCRX
  • Replies Replies 7
Ky'sCRX
i just replaced my axles and now it pulls to the left when you give it gas. do you all have any ideas
hmmm.....I've never heard of axles throing off alignment? Go back and make sure that both axles are securely all the way into place!
did u take out ur axel or did the garage cause u/them may have adjusted the sleeve on the tie rod when u took it off and thrown ur alignment out of balance. does ur car still drive in a straight line?
it still drives a straight line. the problem started because i'm having bad vibrations starting 50mph. so i garage tell me i needed a new steering rack, and i replace both axles. so i still have vibrations and it pulls to the left when you give it gas
