did u take out ur axel or did the garage cause u/them may have adjusted the sleeve on the tie rod when u took it off and thrown ur alignment out of balance. does ur car still drive in a straight line?
it still drives a straight line. the problem started because i'm having bad vibrations starting 50mph. so i garage tell me i needed a new steering rack, and i replace both axles. so i still have vibrations and it pulls to the left when you give it gas
