skillz2k5
My womans 92 teg just died the other day. They were driving down the street and just put put... dead. So I go to check it out and it's throwing no codes, fuel pump runs, fuel comes out of the return line off the rail and the ignition coil does spark when a ground wire ran to it. So we have fuel and spark... well at least to the coil. We didn't get any spark out of the plugs so the wires were swapped with known working wires and new ngk plugs. Still no fire. Motor turns over fine and sounds like compression is good. All the electric stuff works so it's not a bad ground or battery. I would very much appreciate some suggestions here as I am at the end of my rope. The motor is stock and never been swapped. The only thing I can possibly think of is the points inside the dizzy cap were nasty so I cleaned them up and still nothing. Also the out side edges of the screw holes on the dizzy cap are cracked but do not think this would make a difference.
