94H_Ex
Under employed
he would probably be better off going to a junk yard with a sawzall and cutting out the panel he needs himself, then taking it to a body shop or some thing and give them the panel and say. "weld this" then just grind the welds smooth paint done.
as for the interior. Seats, dash, carpet and maybe door panels. then go weld up a 6 point roll cage. B18C1, and whatever way he wants to go with his power upgrades. If you want, I have a gray 92 - 95 dash that you can probably modify to fit. It'll be different if you do it right. personally, I like the 88 - 91 CRX Si dash's. Good Luck with the build.
Btw, after re looking over the pics again. best to just get fiberglass fenders.
