:w00t:CRX IS RUNNING !!! :w00t: i cant believe it !! checked all my connections on the distributor and found the igniter wire was pushed out of the plug a little, plus the black/yellow wire by the fusebox on passenger side was cut in half
...... that was the firsrt time i crunk the crx in 3 years!! it was boiling smoke out of the exhaust and everything !! but i dont giva shit!!
thanks for all the help you guys! everyone was a big help!
anyone think the smoke was bad? im gonna change the oil one day and see if that helps, hell that oil is probably no good by now!!
no problem, and im sure its smoking because it set for so long give it a few days to clear up and if its still smoking blue or white then you might have a problem lol
