d16z6 into ef
deadone000
im running a d16z6 in my ef hatch...one prob...im still running the si ecu...so no vtec...i was thinking bout buyin the msd window switch...but my question is...these "pills"..they have the 3k-3,800k pills. the 5k-5,800k pills & 6k6,800k pills..so im clueless when it comes to that...i want it to kick in at 4,800 rpm till redline at 7,100.. so yea i need major help in deciding on these rpm activation switches...i dont want to convert to ob1 or buy a vtec controller...so help!
if you really want it to run right then you should really get the ecu for it which is the p28 and an obd1 dizzy. it will save you a lot of hassle
P28 with ecu harness
I agreed you you should get the P28 ecu and also you will need an ecu harness/jumper. Also get the dizzy that goes with the engine:rolleyes:
