JDM question
  • Thread starter Thread starter El Capitan
  • Replies Replies 6
El Capitan
Hey, ill be swaping a motor into my 97 hatch, i've been thinking about goin JDM but will there be a problem between the harnesses because ones for right hand drive and the other isn't? or what other problems would i encounter?
Thanks in advance :D
use your stock harness and just add the vtec wiring if you have to. i swapped a motor in my 97 civic and i used my stock harness
alrighty,
one more quick question if i have the ECU from both the old engine D16, and im getting a B16B with one as well which should i use?
Originally posted by El Capitan@Jun 29 2005, 06:59 PM
alrighty,
[post=518376]Quoted post[/post]​
Use the B16B ECU of course...and damn, your gettin a type r motor huh? :thumbsup:
Originally posted by El Capitan@Jun 29 2005, 09:59 PM
alrighty,
dude for sure the b16b ecu man i think you might have some problems with that jdm ecu (still learning about ecus) but you can use a chipped p30 or a chipped p28 i am not to sure about the b16b ecus good luck with that post some pics when you get it done!
you wont have any problems with the stock B16B ecu. The D series harness is prewired for vtec (atleast the 5g civics are) just add knock sensor wire, switch a couple in the harness and your golden. You migh not have to switch any but I am just speakin from my experience when I did my SIR G swap.
[post=518451]Quoted post[/post]​
He has a 97 :|
