swap problem2
  • Thread starter Thread starter evcivic
  • Replies Replies 1
  • Views Views 667
evcivic
jus finished putting in a ls/vtec in ek with the stock dx wiring. it turns on and everything but the idle is pretty off and every time u press the gas is shuts off. checked sensors on throttle, map sensor and they seem to be working ok..... help me trouble shoot>>>>>>>thanxxxxxxxx
check your fuel pressure and then adjust the idle otherwise--on the throttle body probably. Are you throwing any check engine light?
DArin
