yellow88crx
I have an 88 si that I dropped a b16 in, everything is hooked up, I am using a pr3 ecu, car starts, sounds ok, I hit 2500 rpm and the motor cuts out and dropps to a lower rpm I can keep shifting and drive normally as long as I dont break 2500 rpms which kinda sucks. there are codes, I will hopefully have them up tomorrow, but for now any suggestions? I will give you any other info you need.
Thank you!
Thank you!
