Ek6 D16y8 - Tighter Steering?
EK6teenY8
Is there any possible way to achieve tighter steering on an EK6 chassis D16Y8 factory Honda Civic? I would like the steering to feel as if it was an SI. Nice, tight and smooth. Any help would be greatly appreciated!
get a front upper strut bar..and a lower front tie bar. you can also upgrade your suspension bushings to aftermarket polyurethane bushings. other than that, you can get a carbon fiber hood to lessen the weight of the front end a little. if you want to go all out, you can get a chassis brace (i think thats what they are called) and rear upper and lower tie bars. if you did all that, you'd be handiling way better than a stock si.
