92stoccord
Big Member
Don't shave the sunroof!!!
or you could just buy new weather sealing to go around it.
seems like the cheapest, easiest, proper way of doing it.
Well its not just the seal. It rains rust flakes on me when its open and it falls off the track every time I open it. I have to push up on it to close it (takes like 3 tries back and forth to find the sweet spot.)or you could just buy new weather sealing to go around it.
looking good man. what s up with the wheels?
I haven't been able to find a set of rims that I like in a CRX but those rims in 16's would be sex for my taste.
how much do those Work wheels go for?
Im sure you set the valve lash cold but just asking?
Buy this tool, its worth the 20 bucks.
Good job so far, some things I might of done different but overall at your age damn good job.
ohh yeah me likey
low on oil possibly, causing the car not to build enough pressure until later in the RPM band? VTEC 'noid on its way out?
shaved sunroof = fail dont do it
Oil level has always been perfect. Either my solenoid, cam seal or VC gasket is leaking though. I should replace them all.low on oil possibly, causing the car not to build enough pressure until later in the RPM band? VTEC 'noid on its way out?
oil level, dented oil pan, or clogged solenoid are the main issues for vtec being late/non-existant.
also, i know it may not be as fun, but 6k really isnt that bad for an engagement point. My prelude was set at 5900. You couldn't feel the difference but you could see the difference at the track.
