Very simply put(and pretty common I suppose):
I'm going to run smaller piping on the hot side. Say 2". And larger piping on the cold side, say 2.5" like it is now. This will let the air expand even more post-intercooler and let it cool my IAT's down a little bit.
My turbo stuff may be going on hold.....
Its simple, but VERY, VERY cool. Something that nobody else will have but you buddy.
**Edit** Here it is!
Thats right... 1 piece aluminum fool! Had it machined with a CNC machineIt's 5/8" thick and sexy
You may have to tap the holes slightly bigger, but that won't be a problem w/your drill press.
Welding the 3 pieces together woudl have been uber hard if not impossible to do and it not leak. This was the only other option!
You like?
Yay!yep yep yep! It's all yours!
sorry to thread jack but i was reading your build on HT and saw on the first or second page that you did LED's in your cluster..do you possibly have a write-up cuz it came out sick..Yay!
And no awptickes, it's for his oil drain.
And Andrew, I assume you have'nt heard anything form the loser in ATL abotu the turbo stuff?
I say it's kneecap breaking time!
i believe nickbeam was gonna do one but i have yet to see it
