even with all my skill i cant fix my car. help please.
Discussion in 'Other Vehicle Discussions' started by TurboMirage, Aug 27, 2006.
  1. TurboMirage
    the mirage is fixed. video inside. updated sept 22
    the story is this. i'll be blunt.
    i downshifted to 2nd at 90mph. chaos ensued. that is all i will say.
    symptoms i have had since the incedent-
    car BOGS from 4700-7000. sometimes i will get lucky and for a brief moment the car will have full power in that range, but then still bog. from idle-4700 power is normal.
    stuff i have changed-
    spark plugs
    plug wires
    dizzy cap
    dizzy rotor
    I EVEN pulled off the timing cover to discover i was OFF by 1 tooth. fixed that, rotated the motor a few times and it was perfect. put it all back together. same problem.
    what i havent changed YET but is next on the list-
    fuel filters
    crank angle sensor??
    actual distributor
    im tossing a new code, i just havent read it yet. if i reset the ECU, the code pops up within ~20 miles.
    input is appreciated.
  2. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    I did the same thing (more or less) a while back on my Prelude, and it destroyed a lot of shit. Did almost EXACTLY what you're describing, but it wasn't anything in the fuel filter/distributor/injectors. It jumped a couplea teeth on the timing belt, bent 12 valves, and shattered every single valve guide.
    I highly doubt it messed up your distributor, but I'd definitely check the valvetrain before I'd check anything else. If you don't have a way to do a leakdown test, you can pull the head, remove the cams, and with the lights off in the room shine a flashlight onto the top (cam side) of the head, and look at the bottom (combustion chamber side) and see if you can see any light shining through. Light shining through = bent valves.
  3. girls_are_mean
    girls_are_mean New Member
    utah
    I'd check compression. I don't know what kind of car you have but the VVTI celica 5spds where having a problem where people would downshift from a high speed to 2nd gear and would bend all the valves and stuff.
  4. TurboMirage
    its a 2000 Mitsu Mirage 1.5 ;)
    i've got a NEW RPW stage 1 head/cam coming in the mail. not a big deal if something is fucked up in the valvetrain. its complete :) so all new RPW springs/retainers and etc.
  5. phunky.buddha
    Dallas / Fort Worth, TX
    That's what my shit looked like after a mis-shift to 3rd at 90mph. I can't imagine what yours looks like after going to 2nd.
  6. TurboMirage
    hmmm interesting :)
    nice. IF it comes to replacing the bottom end, atleast i can get one for like 200 bucks.
    idk. i think the car would run much worse than it does if there were holes in teh pistons or bent valves.
    on the mirage board, its been noted that piston/valve contact doesnt occur until 5 or 6 teeth.
  7. reikoshea
    Dallas, TX
    but look at the revs we're looking at.....something tells me its time to pull the head.
  8. TurboMirage
    and it will be pulled when i install the brand new stage 1 PnP head/cam :)
  9. civicious
    Houston, TX
    if his pistons were that screwed up, it shouldn't run at all....
    I still vote 'head'
  10. phunky.buddha
    I drove mine with the pistons like that for a good 1000 miles. I didn't immediately know that anything was wrong, not until the engine finally let go with a big "bang" on the freeway and blew oil all over the engine bay.
  11. TurboMirage
  12. Turbo&Auto
    Turbo&Auto Nick Go FAST!!
    East Burg, PA!
    Do a compression check and that should eliminate bottom end or not. Seems like the head though.
  13. NissanNiNjA2nd
    NissanNiNjA2nd Senior Member
    If your timing is on, then the problem is your valves.
    End of discussion.
  14. TurboMirage
  15. TurboMirage
    for the record...
    no weird noises from the motor, and oil/coolant levels are perfectly normal ;)
  16. TurboMirage
    i was thinking about this again.
    buuut unfortunately i dont have the time to pull the head to check. :(
    i'll just run it until it dies, or my new head comes in the mail and i find time to pop it on :)
  17. civicious
    Houston, TX
    leakdown, leakdown, leakdown!
  18. NissanNiNjA2nd
    I agree... gotta be valves.
  19. TurboMirage
    how can i get that leakdown shit done.
  20. civicious
    Houston, TX
    Go buy a CLT tester, and hook it up to your air compressor. Pretty much what you do is put the piston at TDC on the compression stroke (so that all the valves are ideally closed) and fill the cylinder with compressed air. The CLT tester attaches to the spark plug hole exactly like a compression tester does, only the CLT doesn't have a schrader valve (so if the psi drops you can see it on the gauge)...what you're looking for is to see if air leaks out of the cylinder. If it's leaking out of one of the valves, you'll be able to hear a whooshing sound coming from the head.
    It's somewhat confusing when written down, but if you see it in person it'll make perfect sense.
