its easy, it sprays sand.
point it at anything but your hand.
wear gloves.
have fun.
its pretty entertaining.
wear gloves.
have fun.
Looks good, will look better after you get rid of the body kit. Hit up the Honda yard, they have got some CRXs, you could nab a set of fenders and bumpers for pretty cheap.
Yeah, I definitely think thats it. They're grounding it out directly at the starter. It's a smaller gauge wire directly bolted onto the starter. I'll have to check out the connection between the tranny and the frame.if the starter isnt getting a grounf then theres def. a problem somewhere..
i can almost bet its a bad trans ground..which is the one that also runs the negative battery terminal
It's in NE Ohio, you're gonna drive all the way from Indiana?94civicturbo said:wheres the honda yard at around there? i need to hit it up for my prelude
